Hey all together.
Be careful it´s gonna be wild and crazy what I will tell you.
1971 Sport Fury 383-4
Starting Point : All lights work as they should, turn signals, hazards etc.
Since then I added the following things:
TTI Exhaust (no effect I guess)
Tank incl. sending Unit (works - tested with gauge)
headlight door motor - works with igniton and lights on
Autometer tachometer
put in heater core and plugged in the heater/ac switch (blower/fan works fine)
Now please pay attention I will tell you what I saw the car doing today:
All lights are kinda messed up now (gonna tell about different problems):
As soon as the battery is plugged on the red "fuel" is shown in the Speedo - if I hit the brakes it turns off and the brake lights turn on and other way round
all lights still turned off -> ignition on -> light switch still off but rear lights turn on - no clue why.
after like 10sek ignition on the headlight delay relay is going crazy with clicking - stops when turning on the engine
turn signals turn on with igniton on but don´t flash!! - while hazards work fine ignition on and off.
engine runnig - just one of the 4 brake lights work!
Some other weird combinations where happening too but can´t really remember . And I think you guys heard enough
I have actually don´t even a clue where to start because all lights worked fine before I did the stuff above.......
Desperately looking for your help.
Thanks
Thanks
