monaco75
whats up guys?
This is on the '78 d300..
Someone installed a points distributor long ago. I just finished installing a Mopar electronic conversion kit. All the stock electronic stuff was still there, but in miserable shape. Along with the kit, I also made a new under hood harness as all the wiring was shot as well (alt, regulator, ect.).
Well I got nothing.. engine rotates but no fire. I'm getting 12v to the positive side of the coil, as well as the negative side. I sanded the firewall down, and added a jumper wire to the negative post on the battery to make sure I have a good ground on the ecu. Still no change.
Idk what I'm missing. All wire is run the way it should be
Could it be the new ecu? Distributor? I get no pulse from the - post on the coil when starting. Thought the ecu might not be grounded good, but no change after the jumper wire..
