Best Oil for '68 440's...
  1. 70bigblockdodge
    70bigblockdodge Old Man with a Hat
    12,771
    5511
    Jan 19, 2013
    Avonmore Pa.
    I have been using Brad Penn, now Driven GP1 20w50, I also use 15w50 VR1 racing oil and Brad Penn 15w40 diesel oil that I put in my truck.
    Now que all the moans about thick oil in a regular car engine.
    All my cars have stiffer valve springs, .470- .557 lifts. The mellowest one can and does get stuck in traffic idle time is high, it also has overdrive which it lumbers along approximately 2k at 60-65. I don't do many short trips, store, bank, auto parts is the only close things to my house.
    I do not use 10w30 in anything, I consider that winter oil. 10w40 is becoming a obsolete oil, still a 10weight oil, but protects warm like a 40.
    New cars are built different, they don't contaminate oil as bad and they know if you up the weight, so I follow recommended on them.
    Sure I may be wasting some HP on turning the oil pump with thicker oil. I also don't put engines together with high volume pumps unless rpm is going over 6k and full grooved main bearings. All my junk is measured torqued and dropped in used stuff, no machine work (except Barracuda), they all hold 25+psi at heat soaked idle and 50+ at speed. I'll call that good. I say put whatever oil you feel good with as long as it has high zinc from manufacturer, with good detergent package for our stinky engines. Adding zinc to modern oil is not a great idea as mentioned above the detergents negate the zinc like it is a contaminate. Let's face it your driving old technology you need old technology oil.
    I guess I would just not recommend 10w30 or less in our clearanced out worn/leaky engine with a carburetor. Anything above that is fine I think.
    • Like Like x 1
    • Thanks! Thanks! x 1
  2. Gerald Morris
    Gerald Morris Senior Member
    1,382
    328
    Mar 9, 2016
    Tucson
    Know the region very well, having grown up in Ft. Worth. We would cruise the Interstates on weekends hundreds of miles, especially in 1980, when the temperatures made 113F for several weeks around the Solstice. I ran Pennzoil 10W-40 back in those daze.... Running a 1970 Mach 1 Disgustang, I recall the Cleveland ran well with 10W-40 and Motorcraft filters, which I VERY frequently changed.
    Rotella T6 5W-40 still has 1200 ppm ZDDP? THAT's GOOD 2 KNOW! I'm probably good for the Summer Oil here, having just changed it for Tilly, but 1200 ppm normally is my cutoff criterion for using diesel motor oil in a gas V8. I use Bob the Oil Guy for reference also. I try to refer to whatever is the most recent published CREDIBLE analysis.
    Given how clean Tilly's crankcase oil has been, I figure the detergent in the Motorcraft stuff has been working. Suffice to say, overloading one's crankcase oil with all sorts of additives usually results in a spontaneous addition of metal shavings and flakes resulting from having destroyed first the actual lubricant, then the engine. That's why I try to shop for a good level of zinc for the VERY OLD FLAT LIFTERS that 1965-66 built engine still runs. The more recent additives introduced by refiners and synthesizers in these past couple decades were introduced with modern engines
    FOREMOST in mind. While most needs for these higher revving, EFI/DOHC engines might be better served with the recent innovations, I simply don't know how the new stuff impacts our V-XIIIs. I can see me running some single viscocity oil soon though. Valvoline VR-1 has done well with this motor when called on.
  3. twostick
    twostick Senior Member
    2,311
    985
    Dec 13, 2012
    Beautiful Downtown Roebuck Ont.
    Back when your car was new, the levels were 800ish +/- ppm. 1200 ppm is lots unless you are running a solid flat tappet on a lobe that should really be on a roller with big spring pressure.
    Kevin
  4. CBODY67
    CBODY67 Old Man with a Hat
    6,167
    1397
    Mar 27, 2011
    It's been interesting to follow the zddp levels in normal motor oil. SL was (and still is) usually 1000ppm zddp. SM went down to 600-700ppm. SN got back up to about 800, with the newer SN+ and SP having close to 900ppm zddp. Not sure why the increase in the latest blends? This could be a whole 'nuther thread!
    • Like Like x 1
  5. cretin90
    cretin90 New Member
    35
    74
    Apr 5, 2021
    ventura
    (dips toe into pool)
    I've had amazing results on high-revving, high powered motorcycle engines (vintage and new),and seen results with modern car engines using the Mobil1 products. (i've never built a car engine) The newer synthetics are not ester-based, so degradation of seals is no longer an issue, and the 15/50 in particular has 1300ppm zinc to protect the flat tappets in my 300. I considered VR-1 , but is specifically designed for *racing*, meaning high pressures, high revs. I think my 300 maxes out around what? 5k?. Also, it appears VR-1 can sludge if it sits too long in the pan.
    Ultimately, we all tend to go with what we know works. To date, I've had superior results with Mobil 1.
    I hope I'm right.
