Broadcast sheet for my 1975 Royal Monaco
Justin Plant
Moneta, VA
Here it is a piece of paper, that at the same time, tells me everything and nothing about my car. For instance, why not just an "x" in the lines where an option is marked?
What do the numbers mean? How do I decipher it? Sure I already know what the car was built with, well anyway here it is.....
Any ideas on any literature about this would be great.
The numbers represent the variant of that option or part, it is sort of an instruction sheet and parts list.
There are multiple different codes that could go in each box.
Alan
Row 1 is administrative (VON, VIN, items related to shipping or handling)
Rows 2-7 are specific assemblies or the last two digits of a part number indicating a specific part. This is the basis 'what do we use' to build the car. There are many variations on these codes across the entire corporation. This is the 'which' of what the car received.
Ros 8-13 are Sales codes. One letter and numbers can be used to indicate the 'what' the car received. As stated above the car could receive numerous options below a specific number or in a specific box.
GG's white books help with some of what you are looking for in this era. There's not a lot of info on the web for those years.
You might also compare the Sales Code lines/boxes to what's in the Order Guides in the Library at www.hamtramck-historical.com . Also noting which of the individual sales codes also might be packaged together for different option package codes, too.
There's lots of information there, just have to learn how to decipher it. Might have to consult different places to find it all.
Below you'll find an explanation of the sales codes in lines 8-13. I took them from 1974 documentation, except for the ones followed by (1977), that are, of course, from the 1977 Chryco Sales Codes List. Codes L73 and N37 must have been new for 1975.
I drew a blank on code B27, but maybe somebody else knows.
DH43M5D124853
Line 8
H - Heat - A/C
51 = H51 Air Conditioning - Manual Controls
C - Console - Seats - Belts - Flooring
15 = C15 Spl Sound Insul - Type I (1977)
54 = C54 S/Back Bench - Ctr A/R (1977)
92 = C92 Accessory Floor Mats
93 = C93 Carpets
B - Breaks
11 = B11 Std Duty Ft Disc Brk (1977)
27 = ???
41 = B41 Power Brakes - Front Disc, Rear Drum
A - Combination Groups
None
Line 9
G - Glass - Mirrors
11 = G11 Glass, Tinted, All Windows
41 = G41 Mirror Inside Rearview, Day/Nite
52 = G52 Mirror Outside, Left, Remote-Control
F Heavy Duty - Fleet
13 = F13 Alternator 60 Ampere
25 = F25 Battery 440 Amperes
92 = F92 Thermo Ign Vac Valve (1977)
Line 10
J - Miscellaneous Items
11 = J11 Glove Box Lock
15 = J15 Cigarette Lighter
21 = J21 Clock, Electric, Sweep-Second Hand
25 = J25 Windshield Wipers - Three-Speed
31 = J31 Dual Horns (1977)
52 = J52 Hood Release, Inside
55 = J55 Undercoating and Hood Insulator Pad
93 = J93 Insrt/Pnl - Type 3 (1977)
L - Lights and Switches
05 = L05 Map/Cour. Lite
07 = L07 Courtesy Lamps
11 = L11 Glove Box Lite
15 = L15 Ash Rec Lite
17 = L17 Cigar Ltr. Lamp
25 = L25 Trunk Compartment Light
31 = L31 Fnd/Hood Turn Ind
Line 11
M - Mouldings - Exterior Trim
21 = M21 Drip Trough Molding
26 = M26 Molding Wheel Opening
31 = M31 Belt Molding
81 = M81 Bumper Guards - Front
83 = M83 Rr Bumper Guards
61 = L61 Door Lite Sw - Rr Door
65 = L65 Ing Sw Time Delay
73 = L73 Elect Fuel Pacer (1977)
74 = L74 Title Sw Time Delay
76 = L76 Signal - Amp Temp - Fuel
77 = L77 Signal Wash Fluid
[81, from fender tag] = L81 Door Ajar Lamp
Line 12
R - Radios
21 = R21 Radio AM/FM Monaural
31 = R31 Rear Speaker, Single
N - Engine Accessories
37 = N37 Catalytic Exh/System (1977)
88 = N88 Automatic Speed Control
P - Power Items
None
Line 13
S - Suspension - Steering
01 = S01 Std 1" Frt Shocks (1977)
12 = S12 Normal Susp - Ft/Rr ISO (1977)
31 = S31 Std 1" Rr Shocks (1977)
42 = S42 Sway Bar, Front
77 = S77 Power Steering
86 = S86 Steering Wheel 3-Spoke w/Simulated Wood-Grained Insert
W - Wh/Cov
23 = W23 Road Wheels w/Chrome Trim Rings
Y - Vehicle Del. And Handling
96 = Y96 Gasoline - 10 Gallons
X - Export - Canada
None
DH43M5D124853
Line 8
H - Heat - A/C
93 = C93 Carpets
B - Breaks
27 = ???
None
Line 9
G - Glass - Mirrors
Line 10
Line 11
Line 12
R - Radios
P - Power Items
None
Line 13
W - Wh/Cov
X - Export - Canada
None
that's awesome, thank you. X for export? Was it built in Canada? It was sold new in Texas.
Looks amazingly like the one I picked up about 10 years ago in Ohio. Same color (mine had a Vinyl padded top), same front headlights, bumper, grill, etc. Very nice car with a 440 engine and red velour interior and about 68,000 miles.
Unfortunately, it also had severe Ohio rust. I ended up parting it out and saved the 440 and a lot of the interior, hood, front grill and headlights, etc, so if anyone needs parts, I would love to save these things from the metal scrapyard. The front seats are lying outside waiting for the next bonfire, and the hood, bumper, grill are waiting for my next trip to the scrapyard. Too bad for what was a beautiful formal Mopar.
If anyone is interested, I will post a new For Sale ad. I just want them gone...
I could use a right hand side mirror for mine. I got a universal one that would look fine but mounting it will require some custom fabrication.
Could you post a pic of the doorsticker with the full VIN and MDH?
@74monacoHT
Here's what I could find. Notably, the Lights section does not contain a single code, which I find a bit odd. Then you have the remark "Test Drive", which may have to do with this car being an early build.
J91 Instrument Panel - Type 1 may be in connection with H41 Upper Level Fresh-Air Ventilation, that is to say, no airco. Those cars lack the vent on the outer passenger side of the panel.
Y84 and B27 (again!) remain to be solved. @69CoronetRT ?
DM23M4DXXXXXX Broadcast Sheet
Line 1
Sequence Number
B 046009
Vehicle Order Number
815 091085
Vehicle Identification Number
DM 23 M4D ??????
B/For U-C-I
U = US Market
Y - Vehicle Delivery and Handling
17 Lease - Bid - Sale = Y17 Corp Lease Car System
14 S/Bank - S/Car = Y14 Sold Car
84 New Car Service = Y84 ???
95 = Y95 Gasoline - 5 Gallons
Line 2
E - Eng.
63 = E63 Engine 400-Cubic-Inch, 2-Barrel V-8
D - Trans
34 = D34 Transmission TorqueFlite Automatic, 3-Speed
D - Axle
51 = D51 Axle Ratio - 2.71
D8 - Size
82 = D82 Axle Size 8.25"
T-U-W - Tires
U36 = U36 H78 x 15" Bias-Belted WSW
Trim Code
?1X9 = ???, Black
UDF Color
000 = [n/a]
Paint Style
Body Paint
Roof Paint - Style Top
K Stripe
1st
V5X = V5X Molding Body Side w/Vinyl Insert, Black
Line 7
H - Heat - A/C
41 Ft. Heater-A/Cond.-Upr/Vent = H41 Upper Level Fresh-Air Ventilation
52 Seats = C52 Bench Seat
93 Carpet - Dr Mats = C93 Carpets
B - Brakes
27 Rear Size = B27 ???
41 Disc. = B41 Power Brakes - Front Disc, Rear Drum
None
Line 8
G - Glass - Mirrors
41 Mirror Inside = G41 Mirror Inside Rearview, Day/Nite
51 Mirror O/S Lt. = G51 Lt O/S Mir M/Chrome
11 Alter = F11 50 Amp Alternator
23 Battery = F23 Battery 375 Ampere
Line 9
11 Glove Box Lock = J11 Glove Box Lock
15 Cigar Lighter = J15 Cigarette Lighter
52 I/P Mounted Hood Release = J52 Hood Release, Inside
91 Instr. Panel = J91 Insrt/Pnl - Type 1
None
Line 10
21 Drip Trough = M21 Drip Trough Molding
31 Belt = M31 Belt Molding
None
Line 11
R - Radio
11 = R11 AM Solid-State w/Push Buttons
76 Coolant Recovery System = N76 Coolant Rec/Sys
Line 12
31 Rear Shocks = S31 Standard Rear Shocks
42 Front Sway Bar = S42 Sway Bar, Front
77 Power Steering = S77 Power Steering
86 Steering Wheel = S86 Steering Wheel 3-Spoke w/Simulated Wood-Grained Insert
W - Wh/Cov
11 Covers or Delete = W11 Deluxe Wheel Covers
93 Road Wheels = W93 15 x 5.5 Blk Road Wheel
Remarks
84 Test Drive
