angus66
- Joined
- Feb 7, 2014
- Messages
- 102
- Reaction score
- 200
Hello - been working on my 1964 Chrysler New Yorker 2-door project for quite some time - there are pictures of it on here in another thread. January 2024 I had to install a different transmission in the car as the original had a badly JB fixed hole in the side that started to bleed. I grabbed my best looking cable driven 727 I had in longterm storage and the install went great. I have had it in the car for over a year now and had been working great. I mean, the car is unregistered and still in mid-restoration, so it's biggest trip has been around the block a couple of times but mostly in and out of the garage.
Last weekend it stopped going back and forth. It no longer goes in gear. The push-button engages and I knew gear changers were working at the transmission end because the neutral switch wouldn't let the car start when in not in neutral. But that weekend, we (the whole family - heavy car) pushed the car back into the garage and decided to ignore it for a week.
Next weekend, same deal, no-go forward or backward. I checked the fluid still lots and lots of fluid. So I dropped the pan. There was a certain amount of grey sludge in the bottom of the pan - enough to drag my finger through and make pictures. I figure maybe enough to clog the new - last January filter. But other than one black spot - the filter is still very yellow.
My plan next is to, drain the torque converter, install a new filter, re-install the pan, fill with new Transmission fluid then install a clear hose between the cooler lines (so I can see if it's pumping). My hope is that it may come back to life? There was no catastrophic noise, I did check the fluid with the car running and in gear back when I installed this transmission - it was fine. But I am hoping it was somehow low on fluid - it has been leaking a bit via a joint in the cooling line - but could that be enough? Wouldn't it give me a sign it was low on fluid? I added a half a quart when it stopped working - no change.
I suspect this could be that the transmission is thrashed and needs a rebuild (and that's not the end or world) but, other than the grey goop in the pan, no outwardly signs of issues until it stopped working. I have searched the forums and other than being low on fluid, 727s are rather hearty and don't usually go out like this so any insight would be greatly appreciated.
