Do not use store bought regular oil. You need 1200 ppm zinc (zddp), it builds up on surfaces during normal running with lots of oil flying around (highway cruising rpm) like a protection layer, so that when times when not as much oil flying around (idle) there won't be metal to metal contact. The problem with new cam and lifters has a couple of reasons one cam and lifters are new, no layer of zddp built up on new cam also lifter must rotate as it moves over the lobe no spin cam will wipe. Last part of the puzzle is oil formulation, the zinc level is lower in current "regular oil", one to help catalytic converter to last longer and it is not needed in new cars, cams are all rollers now, two is the detergent formula changed to one that will break down and absorb the zinc so mixing oils or additives is not a good solution. With that being said yes lots of people are getting away with common oil in a old 2 bbl 318/383 with a gazillion miles, weak valve springs, and a long time with high zinc oil, I would not do it but that's me. Your valve springs are a lot higher pressure than the originals, I have had good results with vavoline vr1 and brad penn "green oil" and Mobil 1 15w50 but it is a synthetic so okay after break in.
