I don't know where you found this information, but it's inaccurate. You originally said the pump doesn't work while in park (it does), and now you recommend starting a rebuilt transmission and/or new converter in neutral. The correct information is that there is no benefit to starting in neutral for a new converter compared to starting in park, and it's actually better to start a rebuilt 727 in park versus neutral. Park applies the same lubrication circuit 5 psi as neutral but at 5 psi line pressure which fills the dry system and apply gentle pressure to new seals before moving into neutral to apply 55 psi line pressure against seals, then into 1/2/3 to actuate the rear clutch, ending in reverse for the highest line pressure of 230 psi and to engage both front/rear clutches and the low-reverse band. Starting a rebuilt transmission in neutral isn't going to damage anything, but the better method is starting in park.
I feel like I have to defend myself here to the new guy.
So, just so you know, I've read everything you've written, thought about it as coming from more experience and working knowledge than I have. You've most likely done a lot more trans work than I've done or even thought about doing. I never worked on cars professionally and your explanation makes sense to me....
My reference to the pump "not working" is very simplified and written with the understanding of what is happening. Yes, it pumps some fluid... That's really obvious. If we were back in my hydraulics/pneumatic class from years ago, we could argue about if the pump is "working" when it's really just "running" to keep fluid circulating.
As far as my "
recommendation", yea, that's the way it was suggested to me years ago
by someone that knew a lot more about transmissions than I did. He's long dead, so I can't ask him. The trans that I have rebuilt over the years have worked just fine... The best example being a 727 I did 40 years ago (and beat on for a couple decades) that is still doing fine with the car's new owner beating on it on a regular basis, so I couldn't have been too wrong. I twisted a couple driveshafts in that one, but never a trans problem. That said, I'll defer to you as having good working knowledge and starting in park does make some sense
as you've explained it. Chances of me doing another trans is kinda slim these days, so it's a moot point for me.
I have started cars that I've drained/refilled trans fluid in neutral... Mostly for ease of the initial fluid level check before running through the gears (and then recheck). I'll probably keep doing it that way because it's my preference. I'll probably dig out my Mopar trans book a little later and see what they say just 'cause.
