I have a 62 880, 361 motor 2bbl, I upgraded to elec ignition and it ran fine for a few days this is jan 2016, then it would buck and die while at a stop sign, let it cool and it would start again and go a few miles then repeat, coil was so hot you couldn't touch it, I put an autozone gold coil in and things were great till Monday sept 2016. It did the same thing died and the coil was very hot. changed coil to an old mopar coil I had and it started so I bought a napa elchin and installed car runs and drives now, coil is warm from engine heat but u can touch it.
Checked w ohm meter, 14 volts at start and 7 when running pos side, 8.9ohms at the coil to pos and neg post, 1.8 I think from post to post , ballast res is 1.8ohms
My question is why does it eat a coil after 8 months?
Think it was a bad coil? That's 2 now and I will start carrying one and some wrenches, is it a short or? stock wiring. Any help is appreciated.
