surfnturf
Hey guys... I need help on this one. I noticed the other day that my Volt Meter on the Dash was pegged while driving regardless if the lights or AC was on. That said, I figured I would start with replacing the Voltage Regulatory being that the alternator is brand new. I installed the brand new Voltage Regulator yesterday and now the Volt Meter is not showing any charge at all. I took the car for a test drive and upon my return the battery was nearly dead. Both ends are connected properly and the it is bolted to the firewall which should ground it properly as well.
The two options that I found for a voltage regulator are VR101 and VR101-T. The one I put in was the VR101 not the VR101-T. Do you think I used the incorrect voltage regulator, or do you think it is just faulty? Do you have a better recommendation? Both look identical.
