Did the 69 Polara ever come with 14" wheels?
polarnj
NJ
Just wondering, I would possibly like to put the 70-72 Challenger style wheels, but it seems like most of the used ones are the 14" size. Don't feel like spending thousands of dollars on new ones.
Would like 22570r14 tires handle/steer that much worse than the 23570r15 that I have now?
I don't have a '69 manual, but 1970 Monaco / Polara manual says 15 inches for all models. Sedans and hard tops came with 5.5" wide rims and H78-15 tires, all wagons came with 6.5" rims. And the spec tire in 1970 was still biased. Radials not recommended.
From The 1970 Hamtramck Registry - 1969 Dodge Dealership Data Book - Monaco & Polara
You'll see that 15" wheels were standard.
As far as converting to 14" wheels.... It's just not a good idea. Try to find new 14" tires and there aren't many choices in reasonably priced tires. I don't expect this to get better in the future, probably gonna be worse.
The owner's manual that was in my '70 Monaco stated that radial tires could be used, but they would basically "ride rougher" than the standard bias-belted tires that came on the cars that model year. I put some Pirelli P76 radials on mine JR78x15 (8.85x15) rather than the stock H78x15 belted tires to raise it up a little bit so the rear factory dual exh pipes did not drag on some driveway approaches. Accounting for the sidewall flex, too. They worked well. The P76s were claimed to be tuned for American car suspensions.
Not sure about 1969, but some 1970 C-body power drum brake cars had "recessed mount" drums. Basically, the finned portion wrapped around the brake shoes, which meant that some wheels would hit the fins before the lug nut area touched the drums. W23s came on my car and seemed to not have that problem, but other wheels might.
IF you like the look of the E-body Rallye Wheels, look for a '76 Charger SE in the salvage yards. They came with a version of that wheel, but in 15x6.5 sizing. The E-bodies used 15x7s, which is what everybody wants, sometimes. The 6.5s probably need a narrower trim ring. The E-body 14" Rallyes were 14x5.5 . Something else that might look good if you can find them is the 15x7 Polycast wheels that came on '76 Cordobas, just get the trim ring and center cap.
Happy Holidays!
Happy Holidays!
Thx for all the info, not sure how many 76 Chargers there are in salvage yards
Did the 70-72 Challengers or 68-74 Chargers ever come with 15's? Seems like most used wheels are 14"
Just looking at the 1970 Charger / Coronet service manual, which includes Superbee and station wagons, they were all 14 inch. Even 440 and 426 came with 14" rims. Apparently you could get disk brakes with 14" rims with those cars.
There are plenty of 14" tires for sale. Online places including Walmart. If you keep checking back they do have sales a couple times a year. You won't see many 14's at your local tire stores, they stock what they sell and 14's don't sell.
This is a link to Walmat tires IDK why it says robot or human?? Robot or human?
Mastercraft avenger GT on sale for $120 right now. WAY WAY better tire than the crowd favorite BFG radial TA
225/70R14 is a decent size. A similar height and width tire is a 215/70R15.
The 15" has more load carrying capacity.
Interesting, all the muscle cars came with 14 as standard, I'm assuming that applies to the Challenger as well since it's smaller
Check the Dealer Order Guides in the "Library" at www.hamtramck-historical.com (might need to manually enter that address) for the ins and outs of 15" wheels/tires on E- and B-body cars of the target years.
Check the option of the 60-series tires and 15" wheels on the E-bodies.
There were some Budd disc brake B-bodies, but unsure of the wheels that could come with them. The dealer order guides might define that issue.
I happened upon a set of those Charger SE wheels at the local salvage yard. Being that they were not the "golden" 15x7s, they were "normal" wheels (with normal prices). So they followed me home.
1966-69 B body 4 piston disc brakes are Bendix brakes.
1970 went to KH single piston disc brakes. B &E bodies.
There are no Budd brakes on B or E bodies.
Yes 1970 B & E bodies came with 14" wheels standard and 15" optional. The 14" wheels come standard with the disc brakes. The only 1970 B & E cars to only come with disc brakes are Superbirds and AAR/TA. Disc brakes were part of the optional 4.10 Dana axle package.
Now the 1969-1969 426 Hemi B bodies came with 15" wheels standard.
Of those cars listed, the 70 and 71 Challengers had optional 15" wheels, although '72 is 14" only. 68-74 Chargers also had optional 15" wheels, but for '69 one optional 15" wheel was the so called "recall" wheels.
Lot's of the muscle cars had 15" wheels. For example, the '69 A12 Superbee (known as the six pack) with the Plymouth A12 Roadrunner (6BBL) had 15 x 6" wheels standard.
Actually, the Challenger was just shorter. They were wider and weighed about the same.
I went to the 68 C body 15x6 rims,which were standard when equipped with disc brakes. I could not locate any 15 inch rallyes anywhere.When equipped with 14inch,( my 66-68) they were 14x6.
Is yours the Steelies with hubcaps? Any pics? Thx
I can get one tomorrow. on the Coronet I blasted and painted the 15x6 wheels to the color of the car, then Used a nice set of 68-69 dog dish caps. on my 66 Polara , I Installed 15x6 wheels and Installed 1969-71 chrysler full caps, which I think fit the style reallly well.
here you go. The Gtx with the 215/75x14 sits taller than the picture suggests.The polara has 225/75x15 Toyo Tires mounted.
I don't have a picture yet of the 15x6 painted with dog dish caps available.
"Ever?"
As John pointed out in post 12, the applications of 14 and 15 inch wheels vary. What wheels were optional varies.
68 and 69 Hemi Chargers came with 15" wheels.
70 T/A Challengers had 15" wheels.
Consult different sources like data books or ordering guides for a specific applications.
With the fuselage styling, 1969 was first year all C's had 15 inch standard equipment.
Sizes do vary on model/trim level.
Our 69 Fury III aka Frankie had 7 75-15 on 15x5.5 rims.
Skinny tires.
Maggie wanted to keep the factree wheel covers so I installed 22570R15 on M body 15x7 rims.
Fills out the wheelwells and boy what a nice ride!
Skinny tires.
Looks good! What is 7 75 15? Would you have any pics with that size?
Just curious, if they were 15x6 wheels would it look any different with the hubcaps?
