3C's & a D?
1984ish? K car wagon, sadly non-turbo. Scrap yard. By the looks of it the clutch pedal is stronger than the k frame.
The K-cars couldn't do anything right. That is the most horrid instrument panel in the history of motorized vehicles.
The wagon is cool , try to find a turbo, 4spd van of that era
I worked on one once years ago but it sure didn't run like the one in your video. I have always liked the 2.2/2.5 turbo motors.I believe there are turbo minivans in the 11's now. 12's are common. a 5 speed at the strip would be a hand full compared to a race automatic.
. Again one has to look at the times in which these things were produced.
Yep, what i did when machining my last 2.2. Had the machinest machine the block around all 4 cylinders for stainless steel o rings, and run ARP head studs.The 2.2 /2.5 was apparently the last design by the guy who designed the slant 6. If there was a blatant overall flaw was there was not quite enough surface area around the cylinders so if you raised the boost it was not uncommon to blow the gasket especially the stock type gasket. There are ways around it though.
I'm not 100% but I believe one of the shop vans ages ago was an 85 turbo van? Canadian model.
One more thing Daytona "Pacifica"
