twostick
An 11.75" FMJRB-body type disc would be head and shoulders above stock 64 11" drums and were engineered to stop a car of similar weight to a 64 Chrysler.
Kevin.
Kevin.
Wants to buy complete disc brake set complete with spindles, rotors, calipers and all hardware.
Also wants a master cylinder for power disc brakes.
Im going to put this on my 1964 Chrysler 300
You guys should check in with 70_NPORT. He just finished the exact same disc brake conversion you are gonna do.
It's not quite exactly the same, as a 64 300 is not a C-body so none of the usual spindle options apply.
Kevin
And I agree 100% with that, lining material plays a huge role into how well those ole drum brakes will work. Yes, you can have inferior quality with a disc pad also, but the disc is a more effective brake, so still superior.Recently read a letter in Hemmings Muscle Machines where the guy talked about the lining quality....
I would say don't trust that any of the old systems with obsolete low selling parts are going to be exactly what they should be, at least until you have tried them.
Cantflip - I wasn't referring to you specifically earlier about talking someone out of discs, there were other comments about it also.
I wonder how much the asbestos helped the old brake linings to reduce brake fade. Theoretically modern chemistry should be an improvement, however some things the EPA bans will never be equaled (remember Chloridane for keeping bugs our of your house?).
For a 65-72 car OEM discs should be a no-brainer for safety. For this 64 it's a little tougher to find the right parts to retrofit, but afterward it will be the same sensible decision to make. Unless you never drive in traffic, city streets, over 45mph, and/or have complete control of everything in your world.
Agreed... without researching...11" rotor vs 11.75".
.810" thick rotor vs 1.25".
The 4 piston calipers are nice but the rest of the package is less capacity than Factory 11.75 brakes.
Kevin
