Furyus67
I ordered Part#HKT6701 (pre-bent front brake lines for manual drum) from Right Stuff. The brake lines they sent were incorrect (See comparison picture below). I am working with them to ensure the second shipment they send is correct.
Does anyone know the specific sizes of each fitting on the distribution block? I attempted to figure it out using the plastic fittings that came with my MC bench bleed kit. They are plastic though so I wanted to see if anyone else has ever figured out each one. Here is what I got.
Forward most MC line runs to the forward most, bottom fitting of the distribution block.
- Forward most MC fitting size: 9/16 - 20
- Forward most bottom fitting on distribution block size: 3/8-24
Rear most MC line runs to the top of the distribution block
- Rear most MC fitting size: 1/2-20
- Top of distribution block size: 1/2-20
Front Drivers side brake line goes to the rear, bottom of the distribution block
- Front Driver side end of the line: matches to the size of the first brake line sent by Right Stuff
- Rear, bottom of the distribution block size: 3/8-24
Front Passenger side brake line goes to the front top of the distribution block.
- Front Passenger side end of the line: matches to the size of the first brake line sent by Right Stuff
- Front, top of the distribution block size: 1/2-24
