D Cluley
I was looking at options for replacing a distributor and made up these diagrams to help sort out what was needed. Thought it might be useful to have them all together in one place. Let me know if you have any questions/corrections.
1. Original points style distributor.
2. Points distributor with Pertronix module. Pertronix shows 2 different ways to wire their module depending on whether or not you are keeping the ballast resistor and I did mine a 3rd way. I don't remember where I got the info to do it my way, but it seems easier and has been working for 15 years or so. Your mileage may vary.
2a. From the Pertronix instructions with a ballast resistor.
2b. From the Pertronix Instructions without a ballast resistor. You need to check the coil for proper resistance to eliminate the factory ballast resistor.
2c. My Way
3. Original 1970s style Electronic Ignition with 5 pin box and 4 prong ballast resistor.
4. Newer Electronic Ignition with 4 pin box and 2 prong resistor.
2c. My Way
