65MonacoND
Swapped out my turn signal switch due to bad ground on my 70 300. Now both turn signals and brake lights work. Issue is hazard lights flash all the time when signal is not applied. I think it was doing it prior as it made the same click sound and my alternator gauge moves back and forth from the current draw if engine is not started. When I signal for a direction then only that light flashes. It is only occurring in the center position where no lights should be on. Any ideas on what could be bad?
