Exhaust Manifold Heat Control Valve Missing
haywire 440
Get The Cartwright
Arkansas
As shown in the picture the valve and all the parts are gone. Is tapping threads for plugs a good solution?
Those brass bushings will tap out of the cast iron casting. Might be a bit tedious to tap them for a plug?
Alternatively, you can knock the bushings out and put a 4” bolt with washers through the holes.
There were 2 short bolts, one on each side and I removed them thinking they hindered the exhaust flow. But now that I’m re-thinking that it must not matter because that rod, for the valve was in there anyways. Duh.
I was a little concerned the sleeves might twist out while tapping. I like that solution to fill the holes.
Out of curiosity, what’s the manifold for? It looks like you had a blasted and ceramic coated. Looks nice.
It’s for the ‘65 300L that has its own thread called “The cat is out of the bag”. The manifold was originally soaked in a molasses, believed it or not. That did take a lot of rust off but I wasn’t satisfied with the look. It was recently blasted with “well worn slag”.
I’m going to try a product called Slip Plate that is a dry lubricant. It’s supposed to last a good long time. It was recommended over on fbbo.
Slip plate is awsome. You have a few choices that I see. Tap and thread and plug, put a shouldered bot through it so the shoulder hists both bushings. Or take them out and have them welded closed which would be my last choice in case you want to put it back in. Cant be a easy to find manifold. Man your close to me.
Slip plate is awsome. You have a few choices that I see. Tap and thread and plug, put a shouldered bot through it so the shoulder hists both bushings. Or take them out and have them welded closed which would be my last choice in case you want to put it back in. Cant be an easy to find manifold. Man your close to me.
I actually saw your post on Slip Plate and the Canadian guy Stanton too. Others recommended Fluid Film also but I just got a gallon of SP. A lifetime supply for me.
The same here. Definately wear gloves stuff likes skin also. Fluid film is a wax lanolin actually great preservative against rust but will burn right off manifolds.
You could use 'Carriage Head Bolts'? Insert from the Inside and then Lock Nut from the outside....
B
