1945 Chrysler Other | eBay
P.S. I've already got the 50 y/o Hobart in my kitchen.
They must be smoking some really good **** in OK to justify that price.
Can anyone explain this to me?When you mention a Hobart, this is what I think of as I used them for Years in the Air Force.
Air Force orders ground power units from Essex Electro for aircraft maintenance
I wasn't in aircraft maintenance so I can't answer. It's airplane stuff, I just flew on them, and would occasionally would start em up and shut them down.Can anyone explain this to me?
"400 Hz...DC" ???I wasn't in aircraft maintenance so I can't answer. It's airplane stuff, I just flew on them, and would occasionally would start em up and shut them down.
"400 Hz...DC" ???
That is a VERY odd way of rating somethings output.Think of a standard car alternator, which produces alternating voltage at a frequency proportional to the rpm of the alternator. Pass this alternating voltage thru some diodes and you get a DC voltage with ripple component. At slow speed the ripple is large, at high speed it's fairly low.
This big generator will run at governed speed such that the output voltage alternates at 400 cycles. Then the output is chopped to DC with a small amount of ripple. The alternator will have two voltage taps, one at 28V and the other at 277V. The max current output times the voltage for each tap when added together will be 72,000 watts. This is a big MF generator and needs to treated with great respect or it will bite your ***!!!
That works for me, but the description of the generator says 400 Hz DC. So how can it be both? If it has a cycle it has to be AC, not counting dirty DC.Some aircraft have systems requiring:
1) 115 VAC 3 phase, 400 Hz power.
2) 28 VDC power
3) 270 VDC power
Some aircraft have systems requiring only 2 of the above.
I read the description as having both 400 Hz, (obviously AC), and two voltages of DC. That damned comma in there, doncha know??That works for me, but the description of the generator says 400 Hz DC. So how can it be both? If it has a cycle it has to be AC, not counting dirty DC.
Yes its more complicated, but I figured the short story would suffice. Too much detail is boring.That is a VERY odd way of rating somethings output.
