Formal P/N(s) for upper control arm splash shields?
commando1
Sebring, Florida
I swear to gawd they are not in my 1976 factory Parts Book. Honest.
Anybody?
Pleeeze??
I don't know why this posted three times.
Wish I had the number for you Stan. You have to be super frustrated can't find the number, then your computer decides to have a mind of it's own. Time to bring Grumpy Kitty Back?
We'll see. Meeting a bud at the gin mill shortly.
Talk to me at midnight.
In prior times, I tried to order some for my '70 Monaco, so I'd have some. What came in from Chrysler was not an exact match, other than in the shape they were cut in. From that experience, what you end up with might not be an exact match for the OEM production item. Hopefully they will.
Chrysler usually put them in a box, rolled up, so some care might be needed there, too.
Stan, I just seen this.
I'm not home but I'll check my 75 and 78 Parts Books in the morning for you and see if I can find anything.
Stan, is it item #3 that you are looking for?
YES! #3.
I can't make out the numbers, tho.
Can you tell me what it says?
Very weird. My 76 book shows the exact same illustration as your 78 BUT without the the splash shield. Wonder why.....
There are 3 part numbers listed.
3642-993 Seal, Fndr, W/House Pnl to Upr Control Arm, Rubber, Lt.
3726-600 Rt., Rubber w/Alum. Foil
3906-882 Seal, Fndr. W/House Pnl. to Frame Rear, Rt.
I copied this exactly as printed in the parts book. I hope it helps you.
For something of this nature, which might be common from the '74 models and forward, when used, if you find a '74 part number, if that part was changed or upgraded, it would be to the later model year's vehicle as a matter of course. But you have to have the Price Book to track those number changes. Of course, if the '74 part was upgraded in '76, with an appropriate part number, then the '76 number would be the "new number" until it might have been changed in later model years.
The other thing is that should the financial people have tightened their strings and demanded a little bit of cost to be removed from a particular model year vehicle (regardless of manufacturer), these changes were usually made pretty close to the new model production starting, hence, FEW real changes could be made. BUT what could change is small things the general public might not notice (like a less expensive seat fabric, a change in standard equipment in a small way, a few less chrome items, OR, in this case possibly, the deletion of those rubber splash shields in particular model years). Cars still looked the same until you started to notice minor things that were different or "gone".
As for the parts books, they had to be approved prior to the model year beginning, so they could get printed and distributed before show date. If the initial approved printing reflected "no seals", that's what they went with. If "seals" were later approved, it would have been too late to change the books, although a revision letter might be sent later (as was the case with service manuals or ordering information).
Sometimes, these "side issue" situations affect the ultimate accuracy of the parts literature. I've been through several situations where I had to go back one model year to get the correct parts.
Of course, this works only within the particular platform version's production life. In this case, '74-'78 C-body platforms.
I googled those nos. every way possible to the best of my algorithmic/linguistic ability but alas, I am defeated. Zero hits. Nada. Nothing. Total Black Hole.
And find me the guy who omitted the illustration in the damn book.:mad:
Is he still alive?? :mob:
Check with Graham. He has found superseded numbers and parts for me in the past.
