Formal Tail Light Circuit
azblackhemi
Waddell AZ
As soon as I find one I'm buying a FSM for my 74 Monaco but in the meantime can anyone with a good wiring diagram tell me what other if any accessory's are on the same circuit (fuse) as the tail lights? Want to figure out just what I need to trace down.
According to the Fuse Specification section:
Cavity 2
20 Amp
Tail Lamps
Side Marker Lamps
Park & Turn Signal Lamps
License Lamps
Instrument Cluster Lamps (also in Cavity 1)
Clock
Cigarette Lighter
Cavity 3
20 Amp
Stop Lamps
Ignition Switch Lamp & Delay Relay
Dome Lamp
Rear Dome Lamp (wagons)
Map Lamps
Courtesy Lamps
Glove Box Lamp
Seat Belt Lamp
Hazard Flasher Circuit
Seat Belt/Key/Headlights Buzzer
Cavity 2
20 Amp
Tail Lamps
Side Marker Lamps
License Lamps
Clock
Cigarette Lighter
Cavity 3
20 Amp
Stop Lamps
Dome Lamp
Map Lamps
Courtesy Lamps
Glove Box Lamp
Seat Belt Lamp
Thanks! Now I know where to look.
