Fuel pick up 3/8
Fuselage Years
  1. Fredrik Scheffer
    Fredrik Scheffer New Member
    32
    22
    Oct 30, 2017
    Stockholm, Sweden
    Hi fellow C:s. Does anyone know if b-body 3/8 pick up would fit a c-body tank? Have a 69 new yorker. or any other solution to upgrade to 3/8.
    Best regards
    Fredrik
  2. 413
    413 Well-Known Member
    678
    229
    Jan 28, 2019
    NW USA
    No it will not fit a C body. That’s why they are different part numbers. It has to reach the bottom of the tank so they are specific.
    Why do you think you need it? Drag racing 11 second quarter Mile? High RPM driving?
  3. Fredrik Scheffer
    32
    22
    Oct 30, 2017
    Stockholm, Sweden
    Haha not really but since i want new stuff there is no harm in upgrading to 3/8. It was in my opinion a bit thin from start withv5/16. Risk of vapor lock etc. Done it on a b-body with good result not needing return unit or regulator.
    • Agree Agree x 1
  4. Davea Lux
    8,012
    1971
    Mar 27, 2017
    Cornelius Or
    Most C-Bodies ran a 5/16" line. If I remember correctly, there was a 3/8" line and pick up offered on the '70 SFGT with the 6BBL option and as an option on some 440HP police cruisers.
    • Like Like x 1
  5. Pete Kaczmarski
    Pete Kaczmarski Senior Member
    2,477
    1576
    Oct 11, 2012
    Waupun WI.
    Three weeks ago I purchased a new gas tank sending unit for my '70 Fury III ex squad. There was a choice of two and one was the 3/8" pick up. They (Vans Auto | Affordable Restoration Parts for Classic Cars) said there was no other difference. It came with a new gasket and retainer ring. It worked fine and I'm happy.
    • Thanks! Thanks! x 2
  6. 65Fury440
    65Fury440 Senior Member
    2,496
    1031
    Apr 21, 2013
    West Central FL
    I found one on EBay.
    • Like Like x 1
    • Agree Agree x 1
  7. CBODY67
    CBODY67 Old Man with a Hat
    5,329
    1219
    Mar 27, 2011
    Going to upgrade the REST of the fuel lines to 3/8" also? All the way to the fuel pump.
    Just curious,
    • Like Like x 1
  8. CBODY67
    5,329
    1219
    Mar 27, 2011
    In one respect, the normal 5/16" line would have a bit higher velocity of the flow through it than the same volume in a 3/8" line. Which could also mean the slower-flowing fuel in the 3/8" line would have more time to absorb heat on the way to the pump.
    How much time will be spent with the fuel at "max flow" capacity?
    Just considering some of the dynamics of the situation,
    • Like Like x 1
    • Thanks! Thanks! x 1
  9. furious70
    furious70 Well-Known Member
    901
    358
    Aug 18, 2018
    Chitown
    I run 5/16 for my turbo 383 and it's fine
  10. Fredrik Scheffer
    32
    22
    Oct 30, 2017
    Stockholm, Sweden
    Yes of course!
  11. Fredrik Scheffer
    32
    22
    Oct 30, 2017
    Stockholm, Sweden
    Yeah i dont think its a big deal on a original c with 440. It will prob work pretty good with 5/16. But since im going to replace everything i mean why not.
    • Agree Agree x 1
  12. John Kirby
    John Kirby Member
    137
    35
    Jun 3, 2016
    Minneapolis , Mn
    It's not a good idea to route the fuel line next to the exhaust. An electric fuel pump also prevents this issue if mounted by the tank.
