gen 1 viper engine in a 69 fury
  1. moparman1166
    moparman1166 New Member
    17
    0
    Sep 8, 2016
    Beaver Falls NY
    i'm doing research into transplanting a gen 1 viper engine in a 69 fury.
  2. BigblueC
    BigblueC Senior Member
    1,169
    664
    Sep 25, 2015
    Lexington, NC
    Um... Ok. That's pretty vague. Do you have the Viper engine?
  3. moparman1166
    17
    0
    Sep 8, 2016
    Beaver Falls NY
    no, to me the complicated part is the computer wiring.
  4. Turboomni
    Turboomni Old Man with a Hat
    5,443
    2890
    Dec 14, 2015
    MA
    Just buy a Viper. Let the Fury be. Just my opinion.
    • Agree Agree x 3
    • Like Like x 2
  5. 65sporty
    65sporty Old Man with a Hat
    7,608
    1882
    Aug 24, 2013
    Kingston, Mi
    You will need a good factory wiring diagram for the year Viper engine your using and I would want the harness and PCM or if someone makes a stand alone harness with a PCM.
  6. Davea Lux
    8,086
    2171
    Mar 27, 2017
    Cornelius Or
    This is probably not something you can string together in your garage. You would probably be better served to find a wrecked Charger/Chrysler or some other vehicle with the 5.7 engine and grab the computers and the wiring harness. There will be many issues with a bunch of sensors that are not present on your '69. The 5.7 is rated at 350hp, not much of an improvement in power over a T-Code 440. 5.7 also had valve train issues on the earlier variants, so try to avoid those engines. If you are serious about the V-10 viper engine, they are expensive and hard to come by with a lot more computer and sensor issues.
    • Like Like x 1
  7. LocuMob
    LocuMob Fluid Technician with a hat FCBO Gold Member
    11,930
    7772
    Oct 31, 2013
    Blue Earth Mn
    A guy on FTO, also a FABO member, got a chassis from an SRT10, and swapped everything over to his Sweptside. I'll see if I can dig it up, I thought he had the engine running. But keep in mind, it was basically a custom build to fit it all together. Lots of work.
    • Like Like x 1
  8. MoPar Maniac
    MoPar Maniac Well-Known Member
    803
    214
    Dec 8, 2016
    St. Charles county, MO
    • Like Like x 1
  9. mopar440
    mopar440 Active Member
    452
    135
    Oct 17, 2018
    St paul
    Sweet idea, but noooot easy from what Ive read
  10. fury fan
    fury fan Senior Member
    2,205
    523
    Mar 30, 2013
    Indianapolis
    If your goal is a powerful C-body, a well-built 500-550hp bigblock stroker will be far cheaper, simpler, easier to build, etc.
    If your goal is a modern EFI engine, a 5.7 would be much simpler than the 488, and 6.1 or 6.4 would offer more power in the same envelope.
    If you're after bragging rights of an oddball drivetrain, be aware that many of those ambitious projects result in an unfinished car sold at a major loss.
    The 488 is longer, so harder to fit, and you need to change to a Viper-compatible transmission also (it shares the bell pattern with the Cummins). Which means either fitting a 6-speed (major tunnel reconstruction plus conversion to 3-pedal), a 518OD (mild reconstruction) or finding a Cummins 727 (do they exist?) and tweaking it to perform nicely with a high-rev gas engine instead of a low-rpm diesel.
    Plus all the ECU stuff, which will be harder to figure out than the G3 hemi stuff.
  11. commando1
    commando1 Old Man With a Hat on the Porch FCBO Gold Member
    34,687
    19388
    Mar 10, 2011
    FUHOA Reservation, Sebring, Florida
    May I ask your age and experience?
  12. 68PK21 440.6bbl
    68PK21 440.6bbl Old Man with a Hat
    5,248
    2943
    Nov 29, 2017
    Siren City
    They just did this (or was it a repeat?) on one of the ass monkey car building shows on Motor Trend TV with a 60'ish Chrysler 300 and a Gen 1 Viper.
    You may want to rewind the tape, or you may not as the engine didn't fit too well and firewall and tunnel had to be cut out and re-fabricated, yada, yada, yada, par for the course with those shows.
    They went to some exclusive Viper only wreaking yard that had over 400 engines in stock or sold, (I can't remember) I lost interest quick as they kept switching over to some Model A rehab. Then there was the 'bagging' of the 300, :rolleyes:
  13. jake
    jake Senior Member
    1,443
    791
    Oct 23, 2012
    wisconsin
    • Like Like x 1
  14. rags
    rags Senior Member
    1,036
    624
    Dec 14, 2015
    greater norwich metropolitan area
    over complicating it. go the old school route. custom intake with five down draft webers. ignition, um...
  15. MoPar Maniac
    803
    214
    Dec 8, 2016
    The V-10 is only six inches longer than the LA engine its based on.
    • Like Like x 2
