has2bmopar
I have had 9 '67 Chryslers and I don't see within the pictures any evidence of rear heat or defrost. The 2 heater cores are normal with an AC car, and one hose will jump from one core to the other at the firewall.
The panel/speaker covers over the rear seat is a panel used when you have bucket seats with the drop center rear seat.
The metal perforated package tray is flow through ventilation that exits through the dutchman panel. I believe all '67 C-bodies had this, excluding the Convertibles and wagons of course. The hoses in the trunk are drains for the dutchman vent above.
I can't see from the pictures, but if you have rear defrost there will be a single wide vent in the center of the package tray, behind the speaker cover panel. You will also be able to see the blower motor from inside the trunk ahead of the rear vent pan that you have pictured.
I like the car, if you get it and need any easily shipped pieces, let me know and I can see if I can help you out.
Here's one that I sold several years back that you would have liked... It originally did not have a vinyl top... I'll have to scan some earlier pics. Good luck, I hope you get it.
