Rusty Muffler
How far should the fuel pickup AND float be from the tank floor? Right now it's at least 1.5 inches off the floor. Shouldn't the float probably be close to resting on the floor too?
If the pickup and float is 1/2" off the floor and you happen to run your fuel low as the fuel sloshes around it will suck air.I talked to the seller of the tank Vansautollc and he rudely said it was fine. I played it safe and adjusted just the pickup so it's about 1/2" off the floor.
With my 68 I had to bend the float down a smidge, 1/16". The problem was it wouldn't read full. It now goes a touch above full. There are two guys at Van's one is really nice and helpful the other well not so much.I talked to the seller of the tank Vansautollc and he rudely said it was fine. I played it safe and adjusted just the pickup so it's about 1/2" off the floor.
