HEATER PROBLEM
General Discussion
  1. Steven Williams
    Steven Williams New Member
    20
    2
    Aug 24, 2018
    North carolina
    HI,
    I HAVE A 73 PLYMOUTH FURY II. WHEN THE CAR IS RUNNING THE HEAT IS CONSTANTLY RUNNING. EVEN WHEN THE HEAT IS IN THE OFF POSITION. CAN ANYBODY TELL ME WHERE TO START? ALSO LOOKING FOR A BYPASS CABLE.
    THANKS A BUNCH
  2. Xenon
    Xenon Senior Member
    1,641
    592
    May 12, 2011
    Over Yonder
    Logic would tell me that the heater control cable is not hooked up or the heat door is inoperable...
    Soooo, follow the heater control cable from the dash to the heater box.. Cable should be looped on
    end and on a tang of the slider and have a pressed on clip.. Then couple inches along the way there
    is a cable casing hold down which keeps the outer part of the cable from moving..
    Then follow it to the heater box under dash on right side and cable should be hooked to the heat
    control door lever...
    • Agree Agree x 2
  3. traintech55
    traintech55 Senior Member FCBO Gold Member
    3,423
    1627
    Jul 23, 2015
    Hammond, IN.
    Hello Steve, one very important question, Does your car have factory A/C?
    • Thanks! Thanks! x 1
  4. Steven Williams
    20
    2
    Aug 24, 2018
    North carolina
    Yes. It has factory A/C
  5. Steven Williams
    20
    2
    Aug 24, 2018
    North carolina
    Hey Xenon
    The cable is running from the heat control on the dash directly to the heater valve bypass. I know the cable is broken at the heat control dash end , so I've been moving it manually. Is the cable the same on any other bodies?
  6. traintech55
    3,423
    1627
    Jul 23, 2015
    Hammond, IN.
    It has been over 45 years, but i seem to remember "B" and "C' bodies using the same cable.
  7. Steven Williams
    20
    2
    Aug 24, 2018
    North carolina
    Thanks for the info.
