Howdy Pals
FE5 is rally red.
One of the better colors produced by mopar.
9/21 is the SPD scheduled production date
The door tag is the actual end of production date
Nothing out of line there.
Can you post pictures of the door tag and if possible when you have the battery out a picture of the other half of the inspection tag that is connected the trim tag. There should be an inspectors stamp on it. I wouldn't bend it.
Also, if you found the original front seats was there a build sheet in it?
There should be a broadcast sheet under some of your seats. It seems that often times the C's have a broadcast sheet in both the front seat and the rear seat.
There could be a BS behind the glove box or under the carpet. Have seen one in a headliner before also. Keep any scrap you find of the broadcast sheet.
FE5 is rally red.
Sure thing sir. I will get on those requests tomorrow night after work. Guys at work last week were asking about a build sheet/broadcast in this beast and I had no clue where it might be. Those are good clues to search for it.
OK lots of stuff for you folks to check out. First off... seatbelt soup. Not exactly sure what yer lookin' for but here's what I gots. If these aren't helpful let me know specifically what I should be investigating on the C14 option.
Code L1X9 - Optional Possum (OP) equipped Polara. No critters were harmed in the rescue of this vehicle btw that's for reals.
Check out that custom side marker. It's a Polara Custom so I guess that fits right? What do you think, cut up bicycle reflector or.....?
Smoke 'em if you got 'em.
Good evening gentlemen. Tonight's update includes tags.
Not too sure what I was to find up by the battery. There is a metal tab with a couple odd looking holes in it. That the doodad?
OK so it seems I have a seat mystery. If the front/back seats are out of a different model, really unclear on the bench that was loose up front. I found the seat backs in the trunk. Is this bench from a different car as well? Started to put it back together just now.
I was missing one hubcap. Got it this week. Who would have thought having a full set o' poverty would feel so gOooooood hah.
