Captain Rust Bucket
Hello everyone,
I am in the process of replacing the fuel tank in my '65 Newport and have discovered that my fuel gauge is not working. Well, at least I can't get it to work, haha. I'm pretty sure it was working to some degree before I started taking things apart. The float in the sending unit was taking in fuel so the reading was not accurate. After taking the tank out, I was preparing to put the new one in but wanted to make sure my sending unit was working. I was unable to get any reading on the fuel gauge but "empty". While trouble shooting, I realized that there are two wires that the previous owner had connected to the tank. One was the dark blue sending wire that was going to the sending unit and the other was a light blue wire that was connected to the tank itself with a screw (on the front lip). At first I thought the light blue wire was a ground but it turned out to go back to the fuel gauge. Here's where it gets weird, this is what the back of the fuel gauge looked like when I got down there to take a look :
At this point I realized a couple of things, the original pins for the fuel sending wire and fuel gauge feed were missing. The dark blue wire was spliced to the black wire shown in the picture here, the lighter blue wire was spliced to the purple wire shown here and the black feed wire was spliced to the white wire shown here. Also the original voltage limiter was gone. I tested the two that I could reach with a multimeter and got 5 volts on the purple that goes to the lighter blue and 12 volts on the black that goes to the dark blue wire. So today I was able to pull out the instrument cluster after much grief and took some pictures of what I found, hoping to get some help here:
Anyone familiar with this modification? I assume it's a voltage limiter but I don't know how to test to see if it works or if the gauge works and would like some guidance from anyone that has dealt with this. I have the fuel sending unit on the bench too so I would like to test and see where the system is failing but I have no reference for this in the FSM. I have tested the resistance in the fuel sending unit with the multimeter and I got around 80 ohms at empty and around 26 at full. Any help would be greatly appreciated.
