celticwarlock
I'm not sure where to post this, so I'm putting it here. I have a 2000 3500 series van with about 330,000 miles on it which I'll be to putting into semi-retirement over the next few months, but there's an annoying issue I'm trying to solve.
I had an incident on the road recently which forced me to slam on my brakes. A couple of wheels partially locked up, and a minute or two after I began driving again, the ABS and BRAKE warning lights came on (the van is equipped with rear wheel ABS only). I have had no luck clearing the code from the ABS unit (assuming it stores related codes) by disconnecting the battery. I know that some codes remain for a while and eventually disappear if the fault is no longer detected for a certain number of consecutive start cycles, but that's probably not the case here. This was 3 weeks ago, and the van (which I use daily for work) has been shut down and re-started a great many times since then. If it sits for a day or two and I start it, the lights will go out for about 20 seconds or so, then reappear. I hooked up a scan tool that reads ABS faults and it indicated that it couldn't link with the ABS module, so I got no new information from it. A wiring or sensor failure is very unlikely because the system checks itself at each start-up, and there were no detected issues before stomping on my brakes that one time.
That leads me to the most important question: How can I tell if the module is bad? I *hate* throwing parts at a problem, especially one like this. I'd like to know for sure whether or not it failed before getting another one. Is it common for them to fail 'under load', so to speak? I know all this does is disable the ABS feature and won't cause any other problems, but everything else on the van works, and I'll repair this if I'm able to find out what's wrong.
