Has anyone tried putting a modern day automatic trans in there c body? Or is it better to go with overdrive?
yes, I've been running 3.91's and moving down the road at 80mph in comfort for years. No way to do that without OD. Strong off the line and keep up with the Kia's on the freeway.The whole purpose of this question was/is to try and get "BETTER" MPG. car had 2.92 or 2.76 gears OE[ have to look for sure] Has 3.23 now. Was thinking if I put a gear vender in and changed gears to 3.92 range, I could have "fun" when I wanted and better MPG crusing???
Gear Vendors is a good choice, but you’d be better off with a 3.55 rear end.The whole purpose of this question was/is to try and get "BETTER" MPG. car had 2.92 or 2.76 gears OE[ have to look for sure] Has 3.23 now. Was thinking if I put a gear vender in and changed gears to 3.92 range, I could have "fun" when I wanted and better MPG crusing???
if u put in a over drive u havr to modify the trany tunnel for clearance thats wha clay kussuth told me rhen u will only get 90k out of the 4 speed od mopar trany before its shotHas anyone tried putting a modern day automatic trans in there c body? Or is it better to go with overdrive?
THERE R SOME SHOPS THAT SELL A ADAPTOR SO U CAN PUT A 700R4 BEHINND A MOPAR 440 THEY CLAIM IT WILL HANDLE 800+ Have BUT THE GUYS A&A TRANSMISSION TOLD ME DONT DO IT IF U TOW AANYTHING . THE TRANS HAS ALL IT CAN DO IN HANDLING THE CAR LE ALONE A TRAILER / NOW I KNOW U DIDNT SAYIF U EWAS GOING TO TOW WH IT OR NOT BUT IF IWAS U I WOULD STSY AWAY FROM THE NEW ELECTRONIC OVERDRIB=VE STUFF . ITS LIKE THE GUYS THAT TRY TO OPUT A 5 OR 6 SPEED SICK MANUAL YTRANY IN . TALK TO 1 OF THEM OF ALL THE HEADAKES THEY HAD TO GO THROUGH IT GE IT RIGHT (i HAD A FREIND THAY PUT A MODERAN STICK SHIFR IN HIS CHALLENGER AFTER 10 TRYS HE GOT 1 T]RIGHT . NOW HE DRIVES IT ALL OVER BU ONCE ESTARTED HE HAD RTO GO THROUGH IT xause they had chopped up the trany tunnel so much it ewould had costed him tripple to put it back stockIMO Gear Vendors are just as much work and more money than a 46rh . Besides they only have a .82 ish OD if I remember correctly.
