Need some advice on with my new to me van
jct
Home
I would post this on the correct message board, but that is dead af...
It's a 2001 Grand Caravan ES with a 3.8L and autostick. With 108k miles fwd
The only mechanical issue i currently have is my idle speed power steering it's like non existing until i get some rpm's up, I've already replaced the PS pump and reservoir. Only thing i didn't replace is the rubber flex lines feed and return. I'm not yet ready to drop another around $1000 to get the rack and pinion replaced and yes i did use the correct fluid in the system (ATF+4)
The bonus thing it has, freeze me out ice cold front and rear ATC
I can replace the rubber lines with ease
The check valve in the rack may not be working properly. I have found Lucas power steering additive works wonders on sluggish racks and noisy pumps.
My Taurus had a leaky and noisy pump. Used maybe 1/4 bottle and problem solved.
So i would have to use the automatic transmission fluid additive since it only uses atf+4 fluid
