Nice score
vdk2010
Frankfurt, Germany
...on a garage sale this morning! All for just 30€ (~$40)!
including 9 liters FREON R12
Good morning! :)
Great score Julian! Only a fool would have passed on that deal.
This is for metal shaping, right? I thought this and took it with me, along with a metal shaping hammer. And ideas how this thing is called?
I like this small cool old oil pumper
How much R12 do I need to fill a c-body air comditioning?
A Cobbler tool, ok, not what I thought... ;) But maybe good for metal shaping in some kind...
I'm sure it will work for small light items. Maybe if you put the cobblers tool in a vise to hold it it will help make it stable for heavier / larger pieces
I will use it for that when I start with the bodywork!
As I recall, Max charge 5 lbs...there should be a tag on the RV2 compressor that says what the Max charge should be.
Thanks! Good idea to read the tag on the compressor, it says 3lbs max! So I have enought R12 for 6 cars now :)
Or one car 6 times!!! ;)
Vodka, I think you should weigh the container first....
I did, total weight is 17kg - 7,5kg tara = 9,5kg R12 (I don't know the weight of R12, so maybe it's not 9 litres, but definitely 9,5kg)
Actually, it's kind of a moot point because you don't know the weight of the cylinder when empty.
