No power To The Driver Power Seat
dart4forte
Mesa AZ
put the seats back in. Now the power seat doesn't work. I hate electrical.
Check the circuit breaker on the driver's side kick panel. Bypass it to see if the seat begins to work.
Check the connections to the seat motor.
Give the seat motor transmission a light tap.
Also... check the motor ground. It grounds to the A pillar beside the circuit breaker. It may also ground did you put any isolators between the seat mounts and the floor? The motor also grounds there I believe.
Does anyone have a wiring diagram for a 2 way power seat, 65 Chrysler 300?
Technically there's no two way power seat as each direction counts as 2 ways -
There are two versions:
6 way
(1 up 2 down 3 forward 4 backward 5 tilt forward 6 tilt rearward)
OR
4 way (1 up 2 down 3 forward 4 backward)
6 way
OR
Thanks. A lot easier to read. Trouble shooting. Gleaned all connections. Verified I have power. Now I need to make sure the seat has a good ground.
