It was the unique shoulderl bolt that made it special.Man... I could get some high strength aircraft cable and a few high test ring terminals....
I don't have any pictures of the pieces but here is one on my 69 440
That isn't just a spacer at the top, it has a shoulder that fits into the ring, the lower ring just has a bushing in the ring.
The idea is that the bolts do not clamp down or compress the ring.
If you look at the cable in the Craigslist listing you'll see that the inside is rolled in as well. Even with all the bolts torqued down the cable is floating.
Alan
That's not really a Torque strap, or what most people think of a torque strap in general terms ... it's more like a safety strap in case the rubber insulator in the motor mount let's go the engine doesn't spin in the engine compartment and twist all the linkage, brake trans case, trans mount, and bend exhaust etc.
I have seen some of that happen with an early 1960's AF Cracker Box (ambulance)
Now that was thrown together from the local hardware store!
I'm not sure what else there could be, a piece of chain? A turnbuckle? Better yet a solid mount.
The only thing I can think of that isn't a saftey strap/cable would be a solid mount (and maybe the turnbuckle), anything else is there to limit the movement if the mount breaks.
From the Mopar Parts Book: CABLE, Engine Roll,
Alan
first one is way overkill but looks professional, second one is a nice piece and looks like a schumacher which i have bought before and the third one looks like it would work fine when you cant afford the second one. they have come a long way with motor mounts eh.I wasn't or didn't mean to find fault. I think what they did on the police cars is an excellent idea
To me a torque straps function is to limit ALL rotational motor movement toward the pass side and send the power to the rear as soon as possible (also prevents negative effects of broken motor mount rubber insolators).
Here are some examples
I personally would never use the engine mount as a mount for a torque strap to limit all rotational movement for fear of breaking the motor mount mounting points on the motor.
This is what I've used instead
My friend uses the Schumacher poly mounts. Not solid, but close. Not that bad in his 69 Charger. Has their torque strap too, which is basically an improvement on that factory safety strap. He's got a Mopar crate engine and it feels pretty good inside the car. I thought it woulwould be a lot worse, vibration wise, but it isn't. Looks like the middle pic.
The mount with the cross section view,
There is less rubber. That means, to have the same shear strength , the flex is more rigid resulting in more sensory felt vibration.
I'm slipping that in to look smart...
