- Joined
- Nov 14, 2010
- Messages
- 27,959
- Reaction score
- 26,906
trying to figure out why the gauge in my Challenger won't register where I think it should.
Details....
Freshly rebuilt 383 with about 50lbs of pressure on a mechanical gauge.
I converted to a rallye cluster with a known working gauge.
I was hoping to be able to lose the mechanical gauge that is currently zip tied to the e-brake pedal but with a new Standard sending unit the needle barely moves on the gauge.
The engine is grounded and I use no teflon tape on the threads and even took it a step further and ran a jumper wire from the sending unit body to ground.
I then took the sending from the Imp because it works great and it made no difference.
Today I installed yet another good sending unit with a different value and it registered even lower.
I was thinking maybe something was in the oil galley like an old piece of teflon tape that I used in the past that might be partially blocking the port in the unit when running so I plumbed a line from a fitting into a clear bottle and cranked in order to flush out anything in the galley. After which I drained the oil, changed the filter and refilled with oil that I strained through cone filters twice. I did find some stuff in my double filtering process, small soft stuff, nothing alarming but still no changes. Is it just the calibration of the gauge itself?
This is as high as I can get it to register.
Details....
