Well the fact remains Big John that 1960's vintage points ignitions ran 6 volt coils not 12 volt. And is why they worked well in stock cars for many years on 12 volts.
They were a carry over from 6 volt ignitions of the 50's and before and the ballast kept them alive on 12 volts when 12 volts were the norm..
I guess 0n 12 volts the points would burn up yes??,,,,Yes,,
It's amperage that would burn up points and not voltage. The ballast resistor limits the current through the points.
Here's a basic electricity exercise for you. Take a ballast resistor (1.2 ohms) and connect one terminal to a piece of wire. Connect the wire to one terminal of a 12 volt battery. Take your voltmeter and measure the voltage at the unhooked terminal of the ballast resistor. What's the voltage? Here's a hint... it's gonna be 12 volts. Now stick a wire on an ignition coil and connect it in series with the ballast resistor. Measure the voltage at the other coil terminal and it's gonna be 12 volts again. The current that can pass through is a different story.
Ohms law. V=IR
A coil draws about 2 amps when the points are closed. That's good because you don't want more than 4 amps of current through the points. The coil primary resistance is about 1.8 ohms. (This also makes it easier to figure) and is in series with the 1.2 ohm BR. Got me so far? 1.2 + 1.8 = 3 ohms total resistance in the primary. Still with me?
V=IR Voltage = Current x resistance. You have a 2 amp draw so V= 2R You have 3 ohms (1.2 + 1.8) resistance in the primary ignition circuit. V=2 x 3.
Freaking magic ! The answer is 6 volts. This is why you measure 6 volts at the coil with a 12 volt system when it's hooked up and you have a draw.
Now, let's take a coil like they use with a 12 volt system and without a ballast resistor... Typically these are on tractors and such. The resistance is higher on the primary side. Like about 4 ohms... Do the math again.
12=I x 4 I=3 amps, still less than 4.
The problem is that most guys don't understand basic electricity and... shudder... Ohm's Law. Honestly, I've never seen a coil referred to by "voltage". I have seen some (low primary resistance) that are listed to use with a 6 volt system with no ballast resistor. Again, do the math.
BTW, coils in newer cars with electronic ignitions draw about 4 amps... The ignitions can take that type of current and the increased current gives a "hotter" spark.
Now... all this was typed off the cuff and under the influence of some good pain drugs.... So there may be some mistakes somewhere.
