power brakes
JD poly
Alabama
Has anyone converted to power brakes by adding booster and dual master cylinder with stock drums. 1966 Fury III.
It's not challenging - one should swap out the pedal assembly too because the leverage ratio for a manual pedal assembly is much greater, however I have heard that it's just fine using a manual pedal with a booster.
I have no personal experience with the retrofit, but everything if sourced correctly will simply bolt up.
Thanks, would you think aftermarket or salvage yard source.
The correct booster would be a Midland Ross unit. That is the one with the lock ring around the outside. If your salvage yard has one, grab the mounting plate and the pedal while you are at it. You can use the '67 master cylinder which will bolt on the '66 mount plate. You will also need to source the '67 distribution block and fabricate the brake lines from the master cylinder to the distribution block. You would also want to have the salvage yard booster rebuilt.
X 2 on what Davea ^^^ indicated ^^^ —- all of that has to be salvage yard ONLY —-
Because the ONLY thing on that list that is available N E W is the Dual Master Cylinder…..
Stephens Performance has a Mopar salvage yard in Alabama...you may be able to source what you need there
The back plate and pedal assembly are different...here you can see the 4 holes where the booster bolts on
I removed a Power brake booster, backing plate and underdash linkage from a 66 Chrysler Newport that I parted out and swapped it in my 65 Sport Fury. I bought a new dual bowl master for a 72 or newer C body drum brakes and made new lines myself. Easy Peasy. It has been working great for the past 20 years or more.
Note: I was able to test the booster before I removed it and it was working fine. If you cannot test it, you may want to have it rebuilt before installing it.
If you decide to upgrade to front disc's, you need to upgrade to a dual diaphragm booster since disc's require twice as much boost as do the drums.
not to overly complicate your search but I've been running a single diaphram Midland (drum) booster with discs for over 20 years
Is it a 10" single diaphragm? From my research, a single 8" booster will provide 402 lbs of force. Enough for drum brakes. With disc brakes requiring almost double, a single 10" booster would provide 785 lbs of force. Probably enough for discs.
its a 9 1/2...its kinda an apples and oranges deal....original budd style discs on slabsides used 4 piston calipers, a larger diameter master (1 1/8) for the extra volume and a dual diaphragm for the extra force to push it....the 71/73 single piston calipers used a smaller diameter master (1 1/32) and it seems that you can get away with the single diaphragm booster....it's not a "touch it and your head hits the windshield", it just feels like modern power brakes...no, I've never done the math on the amount of fluid moved by the early vs late system....the drum brake dual master would be a 1 inch bore....on a manual pedal the distance from where the pedal pivots to where the rod to the master attaches is a little over 2 inches...on a power pedal its about 6 inches, so the leverage is completely different
I'm sure the factory did their due diligence when they developed your system. According to the formula designed for power assisted brakes, your booster creates 673 lbs of pressure. The master cylinder also has a formula but I don't have that handy. Apparently the 9.5 single is sufficient with your combination.
My research on boosters was due to when I upgraded my 68 Charger from drum to front discs. I used the stock single 8" booster and found the stopping power was not near as good as it was with the drums. When I found the formula the designers use, it made sense as to why my brakes were Piss Poor.
They take the booster diameter and divide by 2 and times that by itself X 3.14 and times that by the actual diameter of the diaphragm to get the force it will apply.
In your case a 9.5 single diaphragm the formula is 4.7 X 4.75 X3.14 = 70.84 X 9.5 = 673 lbs of pressure
In my case my single 8" diaphragm which came out to 4 X4X3.14 =50.24 X 8 =401.9 lbs of pressure
The article went on to say that drum brakes require about 400 lbs of force to lock them up while discs require almost 800 lbs.
that is why when they began putting front discs on my Charger. the started using an 8" dual diaphragm booster since it doubles the pressure to 803.
When I upgraded to the dual 8" unit my brakes are perfect.
