I pulled the rad from Tux today and while at it did some cleaning and painting of areas of need. The rad has a small crack in the solder joint on the top tank just below the filler tube.
The water pump had been swapped out previously but the installed pump was not painted, so I thought perfect time to knock off both. Cleaned up the fan as well.
