Last ones for today
Are you doing the work yourself Bill? Great pics - well documented- provides us all a lesson in car anatomy. Helps me anyway.
I'm loving all the pictures and the progress. I can't wait to see the finished carS.
Are you able to cut the holes for the speakers? Do the cuts cover after the speaker cover goes on?
Can you cut it so that the speaker frame holds the vinyl down? Do you need to remove some under-foam also?
Also, if there are no sharp corners in your cut-out, less likely to tear?
I'm kinda surprised the way that ABC did that.
Did the factory vinyl over the speaker holes?
If not, seems like an error in communication on his part? Meaning, seems he should've asked how you wanted it?
Here are pics of Bob's work with holes. If I'm remembering right the grills are screwed to a round-ish plate that sandwiches the metal and foam between the 2. No holes in the vinyl, the screws are within the roughly 3" diameter hole.
