Slab rear sway bar - 68 Newport
Mike McGuire
new hampshire
Hello Fellow Mopar enthusiasts,
Has anyone installed a rear anti-sway bar in a C-body? If so, would you kindly share a photo or 2 of how you mounted it to the frame?
Thanks,
Mike
One Mopar club member had a '66 or '65 Polara that he added a rear sway bar to. Bar was from a first-gen Cordoba. He said he had to heat it a bit in the bend so it would match the mounts on the rear axle saddles, but other than that, it all fit well and made a difference in the cornering.
Just some recollections,
