I will be doing some maintenance next weekend including new distributor cap, rotor, and plugs. My question is should I also do the spark plug wires at the same time? How long do plug wires last??
Thanks for any knowledge you are willing to share.
There is a resistance test in the FSM. You have to have a meter that will measure 50K ohms at minimum and that means the $10 Harbor Fright version won't cut it.
The other two tests are visual and probably tell the story more than testing resistance. First is obviously general condition with attention to the terminals. The second would be to check visually for leakage and that just involves opening the hood in the dark while the car is running and looking for sparking to ground or another wire.
The most wear you can put on plug wires is handling them... and we've all seen guys grab the wires and yank rather than pulling them off at the boots.
If they look good (pass the visual tests), have a history of not being manhandled and the car runs well, I'd leave them alone.
