Speedo hasn't been correct since I've owned the car. It reads about 20 mph too fast. Finally got around to pulling the pinion gear and its the Red one. The service manual states that I need a white one. So I ordered one off ebay. But the difference between the red and white is ONE tooth. Would that make all the difference?
My tires are 215/75-14 which should equal a 8.25-14.
Also, what do you guys know about the adapter and needing to be in the correct 6-o-clock position? I didn't notice how it was when I pulled it, but made sure to get it correct when I re-installed the red gear. Now the speedo doesn't work at all. Not really wanting to pull it again til the white one shows up though.
The gear that's up inside there, does that move when you shift to make contact with the pinion gear? Or is my 6-o-clock position wrong? There is a nipple on the edge of the housing that points straight down to the ground, so I used that as my reference point. But the service manual pic looks a bit off, they show the bolt hole for the retainer to be at about 8-o-clock when in reality its like at the 11-o-clock on my car. Maybe its a stock photo of a different tranny? or maybe I need to rotate it?
'67 Newport base. 383 2 barrel, 727
