My car has been sitting for decades of minor work but little use. When I got it, it would run with fuel down the throat, and drive but very dangerous....including real bad wiring, almost no brakes and very bad steering. So, after some work, I face a somewhat tight e brake cable set. I have moved it and tried to lube it when doing the brakes. So, am nervous now to use it. If it sticks tight, I am guessing I can just use the adjusters to loosen a bit to remove the drum. Anyone have experience here....thanks.
