hauntedcbody
Hi all, hitting the Canfield swap meet next weekend. Wanted to pick your guys brains. I'm looking for a few odds and ends.
4 barrel intake manifold- Shooting for $50
HP exhaust manifolds- $150-200
906 heads- $150
Are these parts interchangeable between 383, 400, 440? Any casting numbers I should avoid? Any model years I should avoid? I was thinking keep it within 5 years. I have the 400. Currently has a broken bolt for the valve cover which is causing an oil leak. Exhaust manifold is leaking as well. So my thinking is to freshin' up a set of heads... Possibly deck em .060... mild port and polish... That will give the old newport a bit more pep and fix the leak issues.
906 heads- $150
.. So removing the broken bolt on a bench will be nice. I'll probably pretty em up and what not then sell em' on this website.
