If the "warning light" is on the gauge, as a part of it, then that LED light is triggered by the movement of the heat gauge needle. Probably at about the 260+ degrees F level. Reason I suspect that is that on my '80 Newport, when it was having a serious heat issue due to a radiator leak, I was limping in to the house, stopping at every water station along the Interstate, and the needle disappeared from the gauge, and the LED warning light went out. When I got it to the hiouse and under the carport, I raised the hood and let everything convection cool. And although the valve cover gaskets on the 360 were crispy-crittered, NO burnt smell in the Castrol motor oil.
I might be wrong, but the ELB system might have had some temp input for cold start and such, but no real temp input as later ECMs did?
