live4theking
- Joined
- Nov 24, 2014
- Messages
- 12,425
- Reaction score
- 8,476
This car is turning into a great project. It's in much better condition then I thought it was going to be originally.
So, this picture is what they looked like when the came out of the vinegar?Once I got the shafts out of the LCA's, I decided to try the vinegar trick again. It didn't work on the spindles, but the control arms were only covered with surface rust, so I tried again. I bought the cheapest vinegar I could find, and let them soak for 2 or 3 days. Then I steel brushed them, rinsed them with water and painted them immediately with Hammerite like the other suspension and steering parts. I know the grey is not 'resto correct', but I had some white and black leftovers that I mixed – cheap, and it works.
Yep. The rust, grease and grime transformed into some kind of black crusty layer, and I just used the brush and the wire wool you see in the pics. I was really surprised with the results - it was much cheaper/easier/cleaner than sandblasting and still cleaned all the hard to reach areas.So, this picture is what they looked like when the came out of the vinegar?
man this whole change over is less than the 65 - 68 budd brakes ball joints , rebuilt ones are 275 each + s/h . napa new 440 each , with those high dollar rotors and not to mention rebuilding those budd four piston calipers that no rims will fit over . well there is a stock rim that fits yes . wheel cover type rim . glad you found the best for the buck .
Thanks.Don't know how I missed your thread, just caught up. Love the pic's and updates.
