customsportsman
Greetings all,
New member here. New to C bodies, but not new to Mopars. Still have a 1970 Dart, and just sold my 64 Dodge A100 van after 21 years. Anyway, I recently acquired a 1969 Fury Convertible. Overall, a pretty good car. The previous owner was really proud of the disc. brake conversion that "his mechanic" did. I had to re-do all of the metal lines (no big deal, jus sloppy work by the previous owners mechanic). Found that the rear brakes were not working, and fixed them too.
Now, here's the problem(s).
This thing doesn't stop for sh_t! The pedal is rock hard. I have the rears adjusted properly. This thing has a manual proportioning valve for the rears, and I can lock up the rears in a panic stop (not good).
Here's what I have figured out:
1) The master cylinder and power brake booster are from Leed Brakes (an aftermarket disc brake conversion company that sources from others to make kits).
2) The discs and calipers are from a company called SSBC (another aftermarket disc brake conversion company that sources from others to make kits).
3) Brake booster vacuum is fine.
4) I have had to add an auxiliary pull-up spring to bring the brake pedal back to the fully retracted position.
I have no experience with these companies. Apparently SSBC is out of business. I have never had a vehicle stop this crummy before. Perhaps my expectations are too high, but this thing seems dangerous in a panic situation.
1) Has anybody else had this problem? I cannot be the only one.
2) Does anybody have the spindles, backing plate, and master cylinder rod from a donor car so I can go back to drums? Personally, I don't mind drums, and I think they would be better than this setup.
Thanks in advance,
Tim
Northeast of Detroit
Thanks in advance,
Tim
