live4theking
- Joined
- Nov 24, 2014
- Messages
- 12,425
- Reaction score
- 8,476
68 NYer 440 factory Holley 4160 List 3918
I put a renew kit in the carb a few days ago. The car idles fine and pulls about 16# of vaccum. It seems to be running fine down the road as long as I drive gently. If I do a WOT burst for a few seconds when I pull off it won't come all the way back to idle. It's probably a few hundred rpm above idle. Even if I blip the throttle or rev it in neutral it won't come back down all the way.
I pulled it in the garage and removed the air cleaner with it still running and the throttle looked to be in the idle position, against the adjusting screw. When I shut it down it dieseled momentarily. There isn't any fuel spray out the tail pipe so it doesn't seem to be running rich.
When I fired it up just a minute or two later it idled fine again.
Anyone else ever run into something like this?
