bajajoaquin
I took my '67 Imperial in to be aligned today and they told me that I need new inner and outer tie rods as well as adjuster sleeves. Also, the car would require shimming to fully cure the pull to the left.
Looking at the diagram in the FSM, I see a left and right tie rod which both attach to the "Center Link." Looking at the PST website, I see Driver's Side and Passenger's Side tie rod ends, adjuster sleeves, and "inner tie rod ends."
From this, I infer that a complete tie rod assembly is a left or right tie rod end, an adjuster sleeve, and an inner tie rod end (which is the same left to right). If I'm replacing the tie rods, it's two of these complete assemblies, correct?
And should I be worried about "shimming?"
