I got a repop turn signal canceling cam for my ‘68 300 with tilt/telescope steering column (thank you @marty mopar ).
I have never pulled a steering wheel, let alone worked on the inside of the column. I studied lots of YouTube videos, bought a steering wheel puller/compression tool, and got the courage to dig into the project today.
Made my way through all of the removal and made it to the turn signal switch. Once there, I couldn’t initially see anything wrong with the original cam. Upon closer inspection, I could see a little crack near the base of the little lob that holds the left turn signal on (which is why it wouldn’t hold for my left turns).
At that point, I could not figure out how to remove the existing canceling cam (lack of confidence) so I did the next logical thing, went and got some JB Plastic weld for plastic. Let it cure, and seems to be doing the trick…. For now!
