WANTED upper control arm 70 C body
Same part numbers in 69 and 70 for all Plymouth, Dodge and Chrysler according to the book.
2269 104
2269 105
I was just kidding and poking fun at the whole mention of a date code.
Dave, what's wrong with the one you have?
I cleaned up all the old parts , painted up the arms and other parts. Installed the bushings , installed the arm and went to install the joint and it went in way to easy and never tightened up, the ***** is stripped
I had that happen and got a good one from Dana. When it happened though I actually tack welded the new ball joint in which is acceptable but then the new Chinese made joint wouldn't hold its grease...:mad:
I've never had it happen but I can see how it could. I almost didn't get the right side in.
I probably should have did the Firm Feel uppers and avoided any problems
