stu’s68furyiiirat
What’s this bolt on block for its a 318 it’s circled in black I’m just curious what it is and what’s it’s for
I have never seen a factory pet cock valve, after install yes but not from Ma Mopar.should be one on each side and originally came with a petcock valve rather than a pipe plug I believe
Best to put your face right up there for the full effect.. Although you often have to stick a screwdriver in there to break the crust that has formed.As mentiond, the block drain plug. IF you take it out, be prepared for a gush of rusty liquid after you open up the hole.
If you do it right, everything gets wet."Victory" as "de feet" get wet?
It’s still in the carIf that engine is out of,the car then remove all core plugs and clean out the water passages. usually the crud will not all come out by just removing that plug.
3 on each side.
2 in the back bellhousing area
2 on the front of the block.
is it your intent to change those rotten frost plugs?It’s still in the car
of the ones i've done, these are the ones that usually rot first. and for some reason, the mother-f'kers on the backs of the cylinder heads.2 in the back bellhousing area
